Hi, my current problem is that once an incident is acknowledged, new incidents of the same severity (though different incidents) will no longer trigger an alert.
So, say, if I am alerted with a high severity alert and I acknowledge it instead of resolving, no new high severity incidents will alert.
Is there a way to change this such that each new incident will create an alert, as long as it’s not identical to an already acknowledged incident?
Thank you!
there is also a lesser-known setting on each service to force the creation of incidents only. Most folks will not want to do this! but it is available. That setting is in the “Integrations” tab, at the bottom under “Alert and Incident Settings”. If you have integrations set up it will warn you about what’s not available if you disable alerts. I wouldn’t recommend doing this unless you’re in a place where you really, really don’t think you’re seeing the incidents you need to be seeing, in which case you can try it out and see what happens.
